Engine cuts at 2000rpm
crusader13
Post by crusader13 »
Engine fires up fine. It will run normal until the motor gets to operating temperature and then will cut fuel or ignition at 2000rpm. All sensors are new. I have tried recalibrating the tps. Gone through the timing twice. I am new to hondata. Managed to figure out the datalog process and the file is attached.
B20B
RC 370cc
255lph Walbro
S2 IM
66TB
crluver123
Re: Engine cuts at 2000rpm
Post by crluver123 »
TPS isn't working. it's staying at 0% for the entire datalog.
crusader13
Switched the TPS out for the old unit and it seems to have fixed my issue. Thank you.
