S300 red flashing light, and cant upload
jnoll6740
Post by jnoll6740 »
Hi, I am having the same issue. ECU with S300 installed is plugged into the vehicle, laptop is connected to S300, ignition is in on position, and the light at the top right corner of S300 is solid green. D1 is not illuminated and D2 is flashing red rapidly. S-Manager software will not give me any real time info on things like RPM, A/F, engine temp, ECT. I think it accepted a base map, but I'm not sure. Please help!
Re: S300 red flashing light, and cant upload
jnoll6740
Post by jnoll6740 »
44282
jnoll6740
Post by jnoll6740 »
I just tried setting the rev limiter to 1700 rpm. I uploaded the tune to the ecu and it was ineffective. The laptop is not communicating with the ecu and the ecu is not communicating with the laptop.
Who socketed the ECU?
jnoll6740
Post by jnoll6740 »
I socketed the ECU.
jnoll6740
Post by jnoll6740 »
Also, The car is throwing a code but when I try to jump the connector down by the passenger footwell, the cel on the dash does not flash... Could I have damaged the ecu?
jnoll6740
Post by jnoll6740 »
The S300 light sequence is as follows: Plug in usb cable to laptop, then to s300 -> D4 in top right corner lights up solid green -> D2 illuminated green for about 1 second -> then D2 turns red and begins flashing rapidly.
Can you please answer the question about the version of software you are using.
jnoll6740
Post by jnoll6740 »
2.6.7.0
jnoll6740
Post by jnoll6740 »
What is the best solution?
Post pictures of the bottom and top of the ECU showing all the soldering you have done.
jnoll6740
Post by jnoll6740 »
How do I attach images?
In the attachments tab when you reply.
jnoll6740
Post by jnoll6740 »
Thanks! Here are the photos.
